1998 Nissan Pathfinder dash doesn’t light up
The main light on the cluster to light up the board is not working. I replace the fuse but nothing plus all the light on my dashboard doesn’t light up. I don’t know what to do.
question: Is the dimmer all the way down?
question #2- is the headlight switch actually on? I’ve known a couple folks who saw the headlights on because of the daytime running lights and assumed their headlights were on- when they were not.
question #3: was the fuse you replaced bad?
question #4- does the rest of the dash work- ie gauges, odometer, etc.?
Everything work but the light for the odometer light and the dashboard doesn’t work.
ok, now answer my 3 other questions…
the dimmer is up
the fuse are fine
dash light doesn’t come on
one more thing to be sure of :arrow_up:
It is very possible that the lights are burned out. I would check the bulbs.
Yes there are on.
Check if the tail lights are working.
