Dashboard lights stopped working. All I can see is the mileage. Is this a fuse?
The only way to answer that question is for you to actually check for a blown fuse. Good Luck.
Thank you, Mustangman.
Sometimes people notice that the instrument cluster lighting is out but not that the tail lights are out, check the tail lights. Next check the panel dimming switch, a dirty or corroded switch could be the problem.
