Speedo cluster dash lumination lights don’t work. checked switch and fuse they work. No clue why the rest don’t light.all other function lights and gauges work.
Check to make certain that your tail lights are working, as they are often on the same circuit and protected by the same fuse as the instrument panel lights. If the tail lights are working, a couple of possibilities are the rheostat that controls the brightness is defective or there is a chassis ground for the instrument panel lights that isn’t making a good connection.
Well just to let know I got lights fixed…The little tang thing that makes contact with the circut ribbon needed ajusted. laymans terms needed bend up a little to make better contact. WA LA problem solved. thanks everyone for help!
WA LA is spelled voila! Unless it isn’t.
