With a carburetor-fueled car, you manually lean the A/F ratio to the best operation. For a fuel-injected car, an adjustable device called an “Electronic Fuel Injector Enhancer” is used to reset the computerized oxygen sensor to compensate for the addition of HHO. The better HHO generator manufacturers make such devices.
The advertisements and testimonials for these products do not contain references or instructions for this step.  These devices in most instances claim to work on any year automobile without additional hardware, merely bolt-on-and-go, etc, etc.  The various people who come on this site occasionally and claim to have seen an XX% increase in their fuel mileage did so by ONLY installing the electrolysis device and turning it on.  Perhaps I’ve not dealt with any of the “better” HHO generator companies.  I will look into this particular claim.
Gasoline enters the combustion chamber with HHO-enriched air, where it mixes and ignites. You’re aware added oxygen enhances ignition, yes? And hydrogen is 3-times as volatile as gasoline. Ever notice that your car runs a little better in very humid air?
If HHO is “mixing” with gasoline it is only in so far as the gasoline droplets are hovering around in a cylinder with a several% higher concentration of Hydrogen.  Yes, your car does run better in somewhat more humid air.  Therein, however, you illustrate the entire issue at hand.  Humid air is HHO already combined as H2O (water).  It is not broken apart.  When the engine fires it does not break H20 into HHO.  It merely evaporates the H20 into a different state of H20 (steam).  Your car runs better in humid air for a number of reasons, but none of them are for the same reasons claimed to be improved by an HHO generator.  In more humid air preignition is reduced so the car can run slightly more ignition timing.  Heat is kept down on internal compnents, etc.  Humid air typically remains cooler as it is sucked into the engine, and cooler air remains denser (more oxygen) resulting in more horsepower.  This is the same reason why many drag-racing applications use “water injection” in their engines.
HOWEVER, this has nothing to do with the HHO generators being discussed here.  If the only benefits of the HHO are the same as with humid air (H2O) then you can simply inject a mist of water into the engine for the same results with fewer losses.  Water injection has been around for many years, and no one is disagreeing that water-injection has some benefits.  This defeats the purpose of wasting energy to break the bonds apart to trun H2O into HHO.
And no, I am not aware tha “adding oxygen enhances ignition”.  Adding more oxygen than is necessary for complete combustion (thereby creating an A/F ratio more lean than ideal) DOES NOT ENHANCE IGNITION.  In fact, it is detrimental to complete combustion.  A lean condition promotes preignition.  If the fuel ignites too early, not only do you lose pwer from it, but it doesn’t combust completely because it isn’t fully compressed, resulting in a loss of both power and economy.  Lean-conditions also boost heat levels which are extrememely dangerous for iternal components like pistons and cylinder heads.
Hydrogen being 3-times as volatile as air adds nothing to your argument.  You just finished stating that the HHO isn’t being used as a fuel itself but rather that it combines with gasoline.  Now it isn’t “combining” with gasoline, but rather is creating a better environment for combustion.
To put it simply, the “better environment” you’re describing sounds the same as that of mere water-injection.  And do you know why you can’t water-inject a daily driven modern car?  Modern cars take great care to pass emissions standards.  To pass these emissions standards they must run at a fairly hot temperature.  This ensures complete combustion with a minimum of byproducts.  Water injection keeps the combustion temps down to increase horsepower, but if you water inject a modern car you’ll fail your emissions test every time.
If you have any sources that state in some technical terms (formulas, chemistry, anything tangible) exactly how HHO can promote better combustion besides the same way that ordinary water-injection can I’d love to see it.
