Stuck CD Player
My single CD player won’t eject. This is the basic Nissan Sentra FM/CD. Any suggestions?
Pull the fuse to radio and it will likely eject when you reinsert the fuse.
Hopefully it will fire up again too. If not and you want to replace check out ebay.com for a used replacement for what you had.
Probably two CD’s are in the place designed for one. If you can get the radio out most are not so hard to remove the cover and extra CD.I conclude this os not a power issue.
Thanks for the help. It worked!
