I’ve read about and seen videos on how to program (or reprogram) remote keys but I can’t find anything on how to program keyless ignitions. One of my two remote keys for a 2009 Toyota RAV 4 stopped working and the problem is not the battery. Luckily I have two of them but I would like them both to work.
Is my only option to pay a locksmith or dealership to do this? I’ve heard it can cost from $300.00 to $600.00 to replace them.
I’m pretty sure the dealer has to do it. The keyless are just like using the key fobs except it senses the fob nearby instead of having to use it as a key. At any rate when we got our latest Acura with keyless, the second key fob could not be found. They had to order one and then I had to take it in to have it programed with the car. It was interesting that the sales department account was charged about $240 for the fob and programing.
Does the red light on your Smart key continue to blink when you hold the unlock button?
Will the vehicle start when you hold the Smart key against the start button? This is the start proceedure if the transmitter fails (dead battery). The Smart key can be used like an ordinary transponder key when held close to the immobilizer antenna.
When a customer brings me a remote or key with a good battery that no longer works and asks it to be “reprogrammed” it never works. The immobilizer module won’t forget a registered key so there is no reason to reprogram. If the key no longer works it usually gets replaced.
No light means it’s not transmitting, double check the battery. Smart keys need the battery to transmit a continuous or repeated signal for the interior antennas to not only allow the vehicle to start but to warn you if the key has left the vehicle (like in your wife’s purse after you drop her off at the store). Battery life may be as short as two years.
"I just went and had 2 extra keys made for my Crown Vic…Six Bucks at ACE hardware… "
But the keys aren’t chipped. I just bought a chipped key for a 2010 Cobalt and it cost about $60 at ACE. A new proximity keep for the Rav4 will be 20 to 100 times more than your keys.
Speaking of my new key, there was a procedure on the box to program it. It shouldn’t be that expensive if reprogramming is required. The dealer might do it for a lot less than you think:
I put another new battery into it and now it works. Of course there was no light (that I could see and didn’t realize there actually was one) because the new battery was bad. Now I feel like a dummy.
thanks for helping fix my remote and exposing my dumminess.
