Socket Won't Grip Bolt Head
You don’t know what a wheel hub is?
Then the bolt was probably rusted and slightly under sized.
I’ll say it again, remove the steering knuckle and use an impact (manual) driver to remove the bolt… You will have plenty of room to do whatever with it off the car… :wink:
Is there room to get a pipe wrench on it?
It’s been quite a few years but mine came out no problem. Seems to me they were Allen bolts though and it may have lock titebon them. Wonder if the socket wasn’t down all the way or bad socket. One of mine came loose so I used lock tite afterwards.
Nothing worse than “looseage”.
I wouldn’t even consider using a 3/8" drive socket on something like that.
Those are usually very tight and often have threadlocker on them from the manufacturer.
1/2" drive ratcheting breaker bar w/ 6pt sockets and, if it fits, an impact socket for additional wall thickness. The bigger you go, the less stress you have to impart and the more control you can have so it doesn’t tilt off the head while you’re straining…
Here is the exact bolt. It’s an almost 100 ft-lb bolt that’s 17 years old. Try a 3/8’ breaker bar and short socket as shown here. As you can see, even that barely fits above the axle. An extension or flex/wobble socket/extension is asking for trouble on an almost 100 ft-lb 13mm bolt with a shallow head. Agreed with Dave to remove the steering knuckle but try this first if you haven’t already.
Well an extension will get you beyond the boot but have to try hard to keep the socket in place.
I have jacked up knuckle in past to make angle better. Kind of extreme. You can turn wheel to get a bit better angle.
You could also remove the cv axle nut and push the axle back away from the hub a little bit to give you some extra room, even use a FWD hub puller to help push and hold the outer cv axle joint away from the hub… you should be able to rent them also…
Never saw this before. Thanks.
That CV joint is causing the socket to slip off the bolt head. Moving it back as suggested by @davesmopar would help to get that bolt out, but it might not help with the hub removal. In the end, you may have to remove the steering knuckle to get the hub out. Some are just that way, but others will just slip out once the bolts are removed.
3/16 W socket is 11.30 mm
12 mm socket
12.5 mm socket
1/2 inch socket is 12.700 mm
13 mm socket
1/4 W socket is 13.34 mm
17/32 inch socket is 13.494 mm
13.5 mm socket.
14 mm socket
Might try a different nearby socket size. 12 point socket “could” round it out, but might give you more bite and be fine. Or an ultra low profile socket and breaker bar that would clear the CV axle boot.
It’s not from my car, a friends, but i think 13mm
3/16 W is 11.30 mm
29/64 “ ~ 11.509 mm
15/32 “ ~ 11.906 mm
12 mm
12.5 mm
1/2 “ = 12.700 mm
13 mm
33/64 “ ~ 13.097 mm
1/4 W is 13.34 mm
17/32 “ ~ 13.494 mm
13.5 mm
14 mm
If 13 mm don’t fit I’d try 1/2 “ or 33/64 “.
What does this mean?
1/4 whitworth is 13.34 mm
So 1/4 whitworth is close to 13 mm, but there’s even closer 33/64 “ and 1/2 “
Ah, Whitworth.
Quick poll - how many folks reading this have Whitworth-sized tools? I never had a Brit bike or car, so none here.
Nopers, and I have a lot of tools… lol
More that you might need to know:
British Standard Whitworth - Wikipedia
