Our daughter recently had a run in with the garage door frame and knocked the passenger side mirrir off the car. We have been able to locate a replacement part but would like to know if the door panel needs to be removed for access to other bolts or is the mirror held on by the one bolt that can be seen when you open the door?
Have you tried removing the bolt? Is it a remote adjusting mirror? if a remote operating, and you have a mirror to replace, you may be money and pain ahead to have an independent small body shop give an estament(or two estaments) and take the better for your pocket and get it done correctly.
