Should the law be changed on tinted windows?
I’d prefer even greater restriction on window tinting myself. Some folks tend to use window tinting for nefarious and/or intimidating purposes. I think it is safer for the law abiders that law enforcement be able to see who’s in the cars going by.
Polarizing sunglasses are the solution for those who prefer their car have tinted windows.
Heh, heh, have a friend that is a LEO, she has limousine black on all windows, illegal in Florida for front windows. But unlikely for her to be ticketed once she flashes her badge.
There are several types prescription sports glasses that could possibly meet your needs. They typically seal against the face using a soft material like silicone. Some of them can be ordered as sunglasses, though I don’t know what tint % ranges they provide.
But because of the pressure needed to seal like that, you may not find them comfortable in the long term, and they might even create a mark on your face if you wear them too long.
Be a bit careful of prescription swim goggles and snorkle or dive masks - because water has a different “index of refraction” than air, your prescription needs to change. You could contact those companies to see whether they can fill them in a way that will work in the air.
There are also (land) sports safety glasses that do the same thing. They are meant to protect your eyes from collisions, or fast moving balls, etc. Ski goggles (prescription, or non-prescription that fit over your glasses) are another example.
Maybe motorcycle helmets could work - but in warm weather, your head could get very hot inside, because in the car you don’t have an airstream to cool you off.
In any event, you may also have to use a good anti-fog agent, because the seal reduces ventilation. They vary in effectiveness. For another purpose (ice skating while wearing Covid masks) I had fairly good results from Lenscrafter’s very overpriced spray bottle anti-fog fluid. But not nearly as good as with ZenniOptical anti-fog coated glasses, ordered with extra “activator cloths”.
I’m not as sensitive as you. It’s been decades since my Lasik/PRK surgery, so that’s not the problem. I have often shopped at truck stops. They tend to have many wrap around glasses that might fit over your glasses that you can try, and see whether they fit. Also try dollar stores, like Dollar Tree. They might just happen to have a pair that works, cheap. And try lots of other stores, like department stores, as well as lots of glasses stores.
I’ve actually had pretty good results by simply picking glasses frames that fit me well, and bending them to fit better. I buy sight unseen from from cheap Internet glasses providers like Zenni Optical and EyeBuyDirect. They might or might not seal as well as you want - so maybe try several frames. They are much cheaper than brick and mortar stores, so you can afford to. But there are usually tiny places at the edges where sunlight gets through. And both merchants take about 2 weeks to fill orders from the U.S.
Both of those Internet merchants provide glasses that are every bit as good optically and mechanically, AFAICT, as local stores, even if you buy the cheapest frames. There are other similar Internet merchants I haven’t tried. (Dollar stores provide pseudo-prescription glasses that are pretty good optically too, if you look for unscratched ones - but both eyes in the dollar store ones are identical, they don’t handle astigmatism, and they are mechanically inferior - the screws and threads are junk.)
What I did first was to go into a large glasses store, and look to see what frame sizes fit me best. I also took measurements on the width of my face. Internet suppliers can fit me a lot better than any glasses store I have found, because they have a wider range of sizes. In particular, the only ones in stores that come close for me, because I have a narrow head, are child size or small lady’s size, but I’m a man and don’t prefer child or feminine styles - though if it’s just for inside the car, maybe that wouldn’t matter as much.
You also have to estimate the distance between your eye pupils (IPD=interpupil distance). You can do that in a mirror (using your current glasses if you are farsighted). But most people’s eyes come about 2 mm closer together in close vision (though mine are about 1 mm closer) than far vision. (In fact, when I told Zenni-Optical that I wanted my close prescription with only 1 mm smaller IPD than my far prescription, they called me from China to find out if I had made a mistake. Pretty good service for very inexpensive glasses.) BTW, some people have asymmetric faces, so you may have to measure left and right distances from the center of your nose.
There ought to be a type of removable sun shade you could put over your windshield. Maybe you could make one that rolls down from on top to cover the as much of the windshield as you need. Or a big adjustable position piece of cardboard you somehow mount on your sun visors. Or airplane style, where you can position an opaque shade anywhere the sun is. All are probably illegal in cars where I live (Maryland), because in theory you can’t legally block any part of your windshield, not even with a GPS or enlarged rear view mirror or parking sticker, or cell phone (many people do it anyway), but that might not be true in NY. (Do I recall that NY inspection stickers actually go on the windshield?)
The car in the photo is visible inside only because it was carefully positioned where it is backlit from the reflected light off the river.
I have 35% tint all around except windshield, it has a 5% tint strip across the top, and I don’t need backlighting of any kind to see inside my car. Both of my trucks have 35% tint on front door windows, 20% rear door windows and back window and 5% strip across the top of the windshield. I can see easily into both of them, front seat anyway. Rear is a little more difficult and I like that. These are the max legal in TN.
You have a couple options. The place I buy my prescription glasses carry glasses from Rudy Project. I have a couple pair. The other option is sun glasses that go over your prescription glasses. Although style may be a concern.
Amazon.com: LVIOE Over Glasses Sunglasses Wrap Around Polarized Sunglasses for Men Women Fit Over Prescription Glasses with UV Protection : Clothing, Shoes & Jewelry
Here in NH you can’t have any tint on the windshield (except the tint strip across the top). And no tint what-so-eve on the front drivers door and passengers door. Each state has their own laws.
EXACTLY !! So, which states(s) need to change to suit your needs. Or, maybe a nationwide mandate? Which would be pretty near impossible since the states are within their rights to create their own motor vehicle laws. I think I’m starting to see how/why you got your nom de guerre.
My wife wears a pair of sunglasses with side shields that fit over her glasses quite comfortably. She uses them primarily when we go fishing to block sunlight from coming around or through her glasses. They are bulky appearing but solve the problem. As long as there is something like this to solve your problem, they are unlikely to circumvent the window tinting laws for your situation.
Why do you keep dragging up old discussions ? Also this is primarily a US of A Forum and has very few Australian members.
The tint requirements vary across the US and Australian requirements may be similar to some states here. Fo instance, significantly deeper tint is allowed in Texas than Maryland. We have friends that moved from MD to TX. They sold their Saturn and bought one in TX with a much deeper tint, including the windshield. A couple years later they moved back but couldn’t bring their Texas Saturn; the tint was too deep. When they returned, they bought another Saturn.
I flagged it because of the included link.
Sounds like an excuse to buy a newer (or another) vehicle… Most people would have just paid $$$ to have the windows tinted while in TX and then had the tint removed when they were about to move back to MD… :smiley:
Odd, I think all states (including TX) only allow tinting the top 5" or so of the windshield.
It’s been a while and I got the information through my wife. She told me that window tinting precluded them returning to MD with the deep tin on the windows. Maybe it was just the side windows.
Dave, they sold a Saturn sedan and replaced it with a Saturn sedan. That doesn’t look like an upgrade to me.
Could the vehicle be smuggled into Maryland inside an enclosed trailer? Is there a checkpoint at the Maryland border?
The tint shop can easily remove the tint, our dealer’s tint department retints windows frequently for warranty complaints (customer finds a small bubble or piece of dust).
Replacing the windows would cost less than replacing the car, but impractical.
My son’s car has a tinted windshield. A fully tinted windshield is not allowed in Nevada, I drove customer’s cars with tinted windshields at least once a month.
Because this place is so boring. It might be three more years before someone starts a window tint discussion.
That’s factory tint, doesn’t vary state to state, correct?
Isn’t trading in a vehicle for a newer lower mileage vehicle an upgrade???
Point is, even the OP of this tread has/had his tint removed for his state inspection and then retinted according to them…
Years ago any auction vehicle that the company I worked for bought that had tinted windows, I had to remove the tint, so I know it can be done… I also have seen plenty of vehicles have their windows tinted, so it just seems that someone that replaces a vehicle over tinted windows only, is just looking for an upgrade, or they just have more money than they know what to do with one… imo
The customer cars that Nevada has driven that have aftermarket fully tinted front windows are illegal. Whether LEOs choose to enforce it is another story. Perhaps enforcement can only be a secondary offense.
Key Window Tint Rules
  • Front Side Windows: States like California and New York require a minimum of 70% VLT (virtually clear), while New Jersey and Vermont allow 0% added tint. [1]
  • Rear Windows: SUVs and trucks frequently come with dark factory privacy glass on the back windows, which is legal in all 50 states (though some states require dual side mirrors if the back is tinted). [1, 2]
  • Windshields: Full windshield tinting is illegal in every state, restricted only to the top AS-1 line or top 4 to 6 inches.
Me, I would like more tinting, but my experience tint eventually scratches on window that are rolled down, and eventually will bubble around the defogger grid on the back windows. So I just go with the factory tiny and sunglasses. Optometry shops have prescription “sports” sunglasses that wrap around, blocking stray light from entering. Didn’t Clueless33 have a sunlight problem? Anyone hear from him?
his last post was in Nov. 25, He may no longer be with us.
