Has anyone had a problem with their CRV when you make sharp turns at very low speed you feel a kind of vibration or shudder. Feels like the rear end. This is a 4 wheel drive model.Thanks in advance.
Signed Condos
This is a known problem with the rear differential on the later model CR-vs, and the “cure” is to change the differential oil. However, if your car is under warranty, I don’t think that you should have to pay for this unless the manufacturer’s maintenance schedule calls for a change of differential oil at a relatively low mileage.
Thus, a solution exists, but you may have to argue with the service department and/or the factory Zone Representative over whose responsibility it is to pay for the solution at this point.
