I have a 2008 scion xd. Condensate pours from under the passenger side dash when I make a tight left turn, and the blower makes a muffled squeal. Can you help?
The condensate drain is clogged.
The condensate hose could be bent if someone has recently worked on the car, but most likely, it is clogged. Some compressed air can usually clear the clog.
