since the fuel tank is under the back seat (4door) Is there access through interior or is dropping exhaust the only way to get to top of fuel tank?
Pull the seat bottom out and find out. On some cars, it simply pops out, held in with friction fit clips, while on others you have to remove a couple bolts. Either way, it’s a <5 minute job to find out for yourself. I don’t know for sure or I would tell you directly.
that’s where i’m starting. sw oklahoma 110 degree forecast. not lazy just trying to save time.
Well then…
Saturn WHAT ?
Well, I didn’t have much hope in that idea due to safety issues. Sure enough, no access.
Fuel pump, cracked nipple, $558.00 back on the road!!
