My dumbass today hit a curb from being in a rush and it looks like a chunk of my front tire just got carved out and now there’s a sizable gash. Is it safe to drive with this, can i use something to patch it, or is the tire done?
The tire needs to be replaced.
I can see the side cords of the tire sticking out.
Do you really want to find out the hard way that you should have replaced it ? Sidewall damage is not repairable and not good if it completely fails at highway speeds .
Yep, replace it, broken sidewall cords.
That is the automotive equivalent of someone using a band-aid to try to stop arterial bleeding.
As others have already stated, you need to replace that tire.
Sure, it’s safe to drive the car to a tire dealer, so you can replace the tire. This is a RWD car, so you can get away with buying only two tires.
thanks for the information.
vote #85 (approx) to replace the tire.
