If i throw a rod and it goes throgh the oil pan only can i only replace the piston and connecting rod and be ok or not
No, If you’ve thrown a rod there is a TON of damage you can’t see unless the entire engine comes apart.
Just by a crate motor from Chevy and drop it in.
When do you plan to do this ?
