2006 tiburon remote will not unlock driver door and cannot unlock manually, seems to be jammed. pulled fuse out and manual button seems to b jammed yet any ideas.
I have had many door latch/ actuator mechanisms in my hand and could see how they worked and just where a jam could happen, but not the Tiburon. Your going to have to pull yours out of the door and take a look, if your lucky you will see the problem during the removal process and not have to go all the way.
thanks. guess i know what im doing the rest of today,
We are all with you in spirit…good luck.
