Reattach Defroster Terminal
I knocked one of the rear defroster terminals loose from the rear window.
Did a little research and seem to have two options.
1. Resolder the terminal to the window grid. It was a clean break and the grid appears undamaged. I have a 45 watt soldering iron, not sure it’s strong enough for the job.
2. Reattach the terminal with conductive epoxy. I prefer this option, but I’m not sure where I can find conductive epoxy.
Any other suggestions would be appreciated.
Thanks,
Ed B.
A local auto parts store should sell a kit for this type of repair. http://www.popularmechanics.com/cars/how-to/maintenance/4221212
That should do the trick. It looks like Permatex and Loctite make defroster repair kits. I’ll post back with the results.
Thanks,
Ed B.
Tester,
I used the Permatex Defroster Repair kit to reattach the tab.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Complete-Rear-Window-Defogger-Repair-Kit-Permatex_7160063-P_N3239_T|GRP2034____
I’m giving it 24 hrs to dry before I reconnect the wiring, but I checked and confirmed continuity between the tab and the grid.
Thanks,
Ed B.
Well come on Ed! Did it work? We’re all waiting with baited breath!
