Driver side power window switch does not work. Individual windows switches do work. I replaced the power window master control switch - none of the windows work with it - the passenger windows all work with their own switch Window is down - just started 2 days ago.When the master control switch is removed - none of the other windows functioned either.
Sounds like a broken wire, likely where the wiring harness flexes between the door and the body.
