Mystery power window fuse
I have a 1995 nissan pathfinder that had a minor wiring problem which i’ve repaired and put the system back together. but for some reason the power windows will not work , I think or believe it may be a relay or fuse but cannot find any specs. in the owners manual or repair manuals that refer to a fuse or relay for the power windows . where do I find it without going through the costly process of going to the dealership. Please help , when I pass a good looking lady I cant even put the window down and say a rude or out of place remark.
Here are the components that can cause the power windows from functioning.
Power window circuit breaker. Located on the left side of the dash.
Power window ignition relay. Located on the left side of the dash.
Power window amplifier. Located behind the right side kick panel.
