Dodge Caravan, side door window shattered,
appears to be glued on with tabs. What is involved replacing with one from a junk yard ?
thanks !
is this the drivers side, middle window, with the opening window?
i had one blow out years ago. turned out the hinges on the front were corroded and they bound up and shattered the glass.
i took mine to a glazier and they did it.
Autozone has a repair guide for the 84-95 Caravan. This is the section on windshield replacement, the same procedure is used for the rest of the glass on the van. This should at least give you an idea what is involved.
http://www.autozone.com/az/cds/en_us/0900823d/80/10/da/d5/0900823d8010dad5/repairInfoPages.htm
Ed B.
