I use a small $1 spray bottle from Walmart for AT-205. Equate 8 oz plastic spray bottle. Doesn’t seem to be affected by the AT-205 and the size is good for getting into small spaces.
Here’s the Walmart link. BTW, it’s an AT sealant. The 8-oz bottle (no sprayer) is $21.11. It doesn’t actually ask if you are a robot or not. It’s an equal opportunity link.
I don’t know how to link to the info on the Walmart app and I don’t see a uspc code. The manufacturers part # is eqsb0812144. 8 oz small spray bottle $1.
Even Mr. Google has articles saying that 205 is not meant for external use . There are actual products for that purpose. The fact that it does not come in a spray bottle should tell you something.
Yes, ATP 205 (also known as AT-205) can help prolong the life of rubber hoses when applied correctly. This product is designed to rejuvenate and condition rubber components, which can help extend their lifespan15.
Improve the overall condition of rubber components5
However, it’s important to note a few caveats:
ATP 205 is not a permanent solution and will not fix already damaged or severely deteriorated rubber1.
It works best as a preventative measure or on rubber that is still in relatively good condition1.
Some users have reported mixed results, so its effectiveness may vary depending on the specific application and condition of the rubber4.
While ATP 205 can be beneficial for many rubber components, including hoses, it’s crucial to use it properly and avoid applying it to certain areas:
Be cautious when using it on external rubber parts exposed to the elements1.
Avoid applying it to brake hoses or other critical safety components without proper research and caution3.
In conclusion, while ATP 205 can help prolong the life of rubber hoses in many cases, it should be used as part of a regular maintenance routine rather than a cure-all solution for severely damaged rubber components.
References 1 to 4 are all topical applications and all refer back to Scotty Kilmer as the source. Scotty is NOT a good source of information.
Ref 5 and 6 are INternal uses of the product used as designed.
Reference 7 is a guy from 5 years ago with 3650 views…I did not watch it.
These are just as good as that expert car advice you get from your friend’s unemployed cousin who swept floors in an auto shop for 2 weeks before being fired.
