I use a Syringe to suck out PS fluid - it worked well on my Acura.
But on Mazda, there are two reservoirs - connected via a narrow tube - so I had to remove the top reservoir/hose to get to the bottom one - had it done twice and it looks like I emptied 50% of the fluid.
After the first try, perhaps the new fluid (Full Syn) got to work and brought out more dirt.
In the process my Disposable Syringe failed. I am looking for a replacement. Perhaps better if It has narrow tube that can be inserted through the hose so I do not need to remove the top reservoir.
Any recommendation on such product?
I am also looking for a spray bottle to hold ATP AT-205 Re-Seal Stops Leaks. Not sure if “205” might need a special material to hold it.
I tend to go to Autozone or O’Reilly or Amazon.
Thanks for the tip.
