I’ve got a 2002 Corolla with about 70,000 miles on it. The other day I changed the oil and noticed that the power steering pump and lines were covered in what I assume is power steering fluid. It seems to come from the pump itself. I checked the level in the power steering fluid and it is above min. I’m wondering if I have a leak and how I can tell if I have a leak. Other than that the car seems to run fine, with no problems with the steering.
Hint: the lines are covered in fluid.
I’d say the fittings for the lines are leaking.
