HOW CAN I REMOVE A REAR DOOR PANEL FROM A TOYOTA 2002 CAMRY LE
First, disconnect your CAPS LOCK.
The majority of door panels are just clipped to the door with plastic clips.
Get a bunch of new ones as you can safely bet you’ll break a few.
Remove any arm rest screws.
You MAY need to slip a clip off the door handle before removing the panel.
You’ll need a slim piece of metal bar to slide between the door and the panel in order to pry the panel out.
Why do you have to remove it?
- go to library
- find computer
- search thier online automotive repair manual such as alldata, or michell ondemand, etc.
- find how to remove door panel.
