96 Toyota camry inner door panel
Drivers side door. I can get the panel loose but cant see a way to get the handle thru it without damaging the panel. I need to remove the panel to gain access to the outside door handle bolts. The plastic handle on the outside cracked! Imagine that! Cold Wisconsin winters and plastic door handles. Ahhhhhhhhh!
Does anyone know how to remove the inner panel? The one with the arm rest.
Did I mention the gas cap door is also plastic! Ahhhhhhhhhhhhh!
Click This Link And Scroll Down And Find Your’s … See If This Makes Sense!
http://www.autozone.com/addVehicleId,2145801/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152801cd0e7
