I have a '98 Buick Regal. The windshield washer stopped working. It is a part of the turn signal switch along with cruise control, etc. The switch still sends enough power to light up a 12 v probe light at the pump but not enough power to operate the pump. Tried new pump…not the problem.
Used switch is on order(new is $420 !) Problem: I have already spent $100+ to determine that switch needs to be replaced.
Question: I would like to replace switch myself. I am getting conflicting advise as to the ease or difficulty of replacement. ESPECIALLY, does the steering wheel and air bag need to be removed or not ??? HELP ! I am fairly handy and have the time. (recently replaced window regulator)
Is your car a floor shift or a column shift?
~Michael
Hi…
shifter is on the console on the floor between the seats… all Regals '97-05 use the same switch. Any ideas ?
Thanks, Gary
I have to wonder if the switch is really the problem since the power to the pump may come from a module. Have you checked to see if there is a bad connection between the pump and where ever the wire goes to?
Here are the instructions for replacement directly from the manual. I have no idea why they suggest removing the steering column and putting it in a vice. Those steps can be ignored. You will also need to remove the lower dash cover to access the wiring harness.
~Michael
W/ Floor Shift
To Remove:
- Remove steering column.
- Remove the tilt lever.
- Place the steering column in the center position.
- Install holding fixture tool J 41352 (or equivalent) on steering column and secure tool in a vise.
- Insert anti rotation pin J 42640 into steering column lower shroud.
- Remove 2 pan head tapping screws from the lower shroud.
- Remove lower shroud from upper shroud.
- Tilt the lower shroud down and slide backwards to disengage locking tabs.
- Remove shroud protector from the lower shroud.
- Remove 2 torx? head screws from the upper shroud.
- Remove upper shroud.
- Remove the wire harness strap from the steering column.
- Disconnect the turn signal and multifunction switch assembly connector from the inflatable restraint steering wheel module coil connector.
- Slide the turn signal and multifunction switch assembly connectors out of the bulkhead connector.
- Remove 2 screws from turn signal and multifunction switch assembly and remove the switch from the steering column tilt head assembly.
To Install: - Install the turn signal and multifunction switch assembly onto the steering column tilt head assembly.
- Install the 2 switch screws. Tighten the screws to 62 in lb (7 Nm).
- Slide the turn signal and multifunction switch assembly connectors into the bulkhead connector.
- Connect the turn signal and multifunction switch assembly connector to the inflatable restraint steering wheel module coil connector.
- Install the upper shroud onto the steering column.
- Install the 2 torx? head screws. Tighten the screws to 13 in lb (1.5 Nm).
- Install the shroud protector onto the lower shroud.
- Install the lower shroud onto the upper shroud.
- Line up the tab slots on the lower shroud with the locking tabs on the upper shroud and tilt the lower shroud up.
- Slide the lower shroud forward until the tabs snap in place.
- Install the 2 pan head tapping screws into the lower shroud. Tighten the screws to 31 in lb (3.5 Nm).
- Remove the steering column anti rotation pin from the lower shroud.
- Remove the steering column and modular column holding fixture from vise.
- Install the tilt lever.
- Install steering column.
