I have a 2005 Toyota Avalon with 26,649 miles, I was told I need front brake pads, what is a reasonable price to pay?
It depends on which pads you choose. I usually spend about $20 for a pair of pads, but that doesn’t include the cost of labor for installation. If you have them professionally installed, expect to pay between $100 and $150 per axle.
Reasonable cost depends on local labor rate. Decent quality parts with legit mechanic markup is likely $150-$200/installed.
I ran a quick price check for pads, and if you require ceramic as OEM (it appears you do), then name brand aftermarket (Wagner) pads run about $65. There are few cheaper choices, so your repair may run closer to the $200 per axle with labor.
Unless you do a lot of stop and go, I would also expect the OEM pads to last longer than 27K. I realize driving habits are key here, but I would want to make sure the calipers, etc, are checked out for proper operation, and did not cause the pads to wear prematurely.
Wagner are EXCELLENT pads. I’ve been using them for years.
I just posted elsewhere on this site, but you may want to check out repairpal.com - information about price for zip code specific repairs in many categories for specific models and years. Allowed me to recommend pad and rotor replacement when my daughter called from a repair shop asking, “Is this a good price”.
It depends whee you live. If the cost of living is high where you live, expect to pay more than the $200 suggested elsewhere. Try repairpal, recommended above, and let us know how it works.
