on my 1990 chevy 1500 series i can’t get my blinkers to work the fuse is good as well as the bulbs and i’ve tried replacing the electronic flasher but it didn’t do anything for it any suggestions?
I bet you replaced the wrong flasher. The hazard (4 way) flasher is usually the easiest to replace, and the turn signal flasher is buried somewhere in the dashboard. Put the hazard lights on and feel the flasher. If it’s clicking, it’s time to play “find the other flasher”…
thanx for your input i tried to find the second flasher but mustn’t have looked hard enough thanx
Try to find someone else with the same make model and year. Have they turn on the blinkers and then track down the flasher by listening for the sound.
