What would cause these lights to come on?
Is the Check Engine Light also lit up?
Could be a failed wheelspeed sensor, could be a failed accelerometer, could be a failed ABS modulator, could be a failed connection to the engine computer. It needs to be scanned by a tool that can read ABS codes as well as OBD2 codes. That’s the place to start.
No it is not.
Thank you.
It could be something as simple as a faulty brake lamp switch
Some auto parts stores will read your abs codes for you for free
If you find one that does this, please report the code to us
Ok thanks.
