What is the normal fuel consumption for a Jeep Renegade? I have had mine for just over a year and bought it brand new. I was just told this is not a known issue and losing 1 quart every 1300 miles is acceptable.
Heidi, I guess you have a 2018 not a 2019 . Are you asking about oil consumption ? Are you using the correct oil and changing it as often as you should. If you do not like the answer the dealer is giving then you can go to another dealer or look in the manual for contact info to corporate. It sounds like you are checking the level on a regular basis but you might even do it more often just to be safe.
