2016 Chevrolet Malibu - Washer quit
my 2016 chevy malibu windshield washer quit working you can hear it working but no fluid
Most likely the hose going to the spray nozzles has gotten a hole in it.
The hose theory above is likely correct. But the nozzles can clog up as well. The problem w/this theory is that both wouldn’t usually clog at exactly the same time. If I suspect a nozzle clog on my vehicles, I’ll try running a 30 awg wire through the hole. The most common cause for this symptom in my experience is pump failure, but thankfully that doesn’t appear the be the case.
Or clogged nozzle that sometimes can be cleaned out with a paper clip.
