2015 Toyota Tacoma - Wet seatbets
Has anyone had problems with both front seatbelts getting wet after a rain? Or loud wind noise on the passenger side door?
Wind noise from door area is often caused by a faulty door seal. One way to test that theory, tape the seal area all around the outside door. If noise goes away, faulty door seal is likely the problem.
Faulty window seals can cause it to, same test method applies.
Make sure to use the kind of tape that is easily removed and doesn’t mar the finish.
