Driver window switch will roll window down, no problem. It will not roll back up until the car is parked for sometime. This sounds like I have a defective switch.
I’m inclined to agree.
Thank you for your help,
That is what I was thinking. I will replace the switch.
Paul
I assume when you try to do an UP that there is no noise from the motor. If there is a noise, then the problem is not the switch.
That is correct. There is no noise from the motor.
Thank you for your help!
Paul
