My key fob has a remote starter that is really sensitive, If it get bumped the car would start and go right back off, and when I go to start the car it would not start, I would have to wait a few minutes before it would start. Is there something wrong with the key fob?
You should have two key fobs , do they both act this way ? Have no idea where you are located but if the remote start is not necessary check the fuse diagram to see if you can disable the remote start . Other wise you are going to need a repair shop.
