2017 Chevrolet Camaro - Keyfob issue
camaro wont start from keyfob anymore
First try changing the key fob battery if you have not already.
there have been a couple of TSB on this problem, so you might want to ask the dealer. here is one of them…
temp.xml (nhtsa.gov)
also, the receiver module for the system could be bad. There is another TSB that exists because a lot of the modules were bad. There is an updated module with a different part number
I assume you have two fobs. Do both have this problem?
Is the check engine light on? The ECM/BCM may limit remote start if it detects an issue.
