Has anyone gotten DTC code P0014 , exhaust camshaft position sys. performance
OBD-II Code P0014 is defined as a “B” Camshaft Position - Timing Over-Advanced or System
Your engine uses "Variable valve timing.
Are you using the manufactures recommended oil viscosity.
Yosemite
Yes, I have had this code for about a month now, replaced both my intake/exhaust solenoids. Still running rough and idles down to 500RPM and sometimes dies out in reverse. Car only has about 50K miles on it and same code keeps popping up. Ive used new solenoids and factory ones and still the issues remains, don’t want to resort to taking it to the dealer.
v6 3.6 motor?
