2009 Hyundai Sonata - TPMS
TMPS light -not the horse shoe symbol- came on several times, even when tires were 35-37 not low . I was due for new tires, so I got new ones. The sensors & air pressure checked out fine each time I had it checked at America’s tire. I see the Hyundai - Technical Service Bulletin 08-SS-010 - TPMS (TIRE PRESSURE MONITORING SYSTEM) SENSOR MODE SETTING link but link does not work. Any advice if it is a known problem?
12 year old sensors, their batteries are probably dying, time for new sensors.
Did your shop have the correct tool—the exciter scan tool?
Tire pressure sensor initiation
NOTE: In the following procedure, a TPMS exciter scan tool must be used.
NOTE: When four sensors have been learned as road wheels, it is not possible to learn new road wheel sensors on the same ignition cycle.
NOTE: Do not perform this procedure if the vehicle is parked on a metal floor, roof or on an alignment rack or lift. The metal will transfer the RF signals, which can cause the learn procedure to fail and set diagnostic trouble codes (DTCs).
NOTE: The sensor’s default state will be Storage Auto (High Line).
  1. Using TPMS exciter, change the sensor mode to Normal Fixed Base (Low Line). See Figure 1.
NOTE: Sensors which were already configured as Base (Low Line) will take longer to read.
  1. Holding the TPMS exciter within three inches (76 mm) of the sensor valve, read each tire pressure sensor ID in the following order: front left, front right, rear left, then rear right.
  2. Connect the TPMS exciter to Data Link Connector (DLC) located under left side of instrument panel. Register the four sensor IDs to the receiver (see Figure 2 and Figure 3).
NOTE: The TPMS receiver will complete the learn procedure of the new sensor after the vehicle is driven up to 20 minutes at speeds over 12 mph (20 KM/H).
  1. Cycle Ignition, wait four minutes and check that “NORMAL RECEIVER STATE” is now displayed.
On 2009 Hyundai Sonata you have to relearn the new TPMS sensors. The relearn process is through OBD port using OBD TPMS Tool, they had to do it in the shop.
Me calling the above post Stealth Spam because of the link in the profile.
That seems like a generic response, no matter what is in the poster’s profile.
I saw his profile a few hours ago, it is a link to a website (not in English), of TPMS sensor(s)…
Welcome @john_195438, make sure to be very careful of posting any links on here, they could be flagged as spam and removed… We welcome most all input and help, just make sure to read through and follow the rules…
BTW the forum is based in the USA…
No worries, I’m not here to spam. I’m from Europe and deal with TPMS sensors quite a lot, including US cars with 315 MHz systems. Just thought I could share some experience on common issues and relearn steps.
Since you’re from Europe . . .
will an illuminated TPMS light generally cause a car to fail the required safety inspection?
Yes, here in Europe (atleast in my country) an illuminated TPMS light can cause the car to fail the periodic regular safety inspection. It has been required since 2018, and the same applies to other safety systems like ABS or ESP – if they are not working properly, the car will not pass.
OK , what country is that ?
From previous posts concerning TPMS, seems some manufacturers take pleasure in making them unnecessarily complicated.
