My 2008 cts Cadillac Is Experiencing ABS Sensor Problems I Was Lucky Enough to Get The Exact Part For My Vehicle And The Expert Working On It Is Having Problems Programming THE ABC Module Any Takers to Resolve This Problem
Might try giving us the ABS code and or the Exact parts name… ?
Possible you may need to find a better Expert mechanic…
Ask your “expert” to double-check they are using the correct scan tool and software as required for your vehicle. You may need to have this done at a dealership.
