ckeck light curise control light is flasking and stability light is on
Cruise control and stability control have been disabled because the check engine light is on. You need to find out why the check engine light is on and correct the problem. Most shops and many auto parts stores will scan the code for the check engine light and tell you what it is and sometimes give you some idea what it means.
