I have a 2006 subaru b9 tribeca with approx 180,000 miles and abs, power steering and brake lights popped up on the display column. Any one know what might this issue be?
you need to have the check engine light codes read and posted here for us to really help. but if your brake fluid is low the brake/abs warning could pop up.
If the primary brake warning light turns on the ABS light will automatically turn on.
That’s because the ABS won’t function if there’s a problem with the primary brake system.
Once the primary brake system is repaired so the light turns off, the ABS light will also turn off.
The power steering light may be caused by a faulty pressure switch.
