2003 Honda Accord Sdn - Power issues
Car will crank only. No spark/no fuel. The door locks or windows fail to operate. Fuses and relays are ok. All lights work as well as the sunroof. New fuel pump. 4 cylinder EX.
How did you confirm no spark or fuel?? Scanner using Live Data, and or Noid light, etc??
And did you check EVERY fuse, or just the ones you thought mattered??
Did it the old fashioned way, Pulled the gas line-no stream. Pulled the plug-no spark.
possibility you have a Faulty crankshaft position sensor – This sensor must detect engine position for spark and fuel.
Gas should pump out of the disconnected fuel line when the ignition is turned to the on position.
The computer commands the fuel pump to run for a second or two to prime and build fuel pressure in the fuel system before starting the engine.
Sounds like an electrical issue.
I have not tested the multi-purpose relay as yet. will check that out.
will check that out-thank you
