I need to replace the washer pump on my 2002 Saturn Vue 3.0L V6. Is this a difficult task? How long should it take if I do it myself?
The pump is located at the bottom of the washer fluid reservoir. If you can easily access the reservoir, replacing the pump should be simple. Some vehicles bury the reservoir inside the fender, which makes the job a bit more complicated and time-consuming.
You may find additional help here:
http://www.saturnfans.com/forums/
Search/post in the Vue Tech Forum.
