Hi,
My Vue has developed a high pitch vibration that appears to come from the right rear wheel. This vibration and sound dissapears when the Vue in in a right hand bank or turn. Any thoughts on whether this issue is a Wheel Bearing or the Axle shaft and how to correct the problem? Thanks … MHO
I would suspect the right rear wheel bearing as the culprit.
Have your mechanic check it and replace it if necessary.
