Runs fine 98 percent of the time. Occaisionally will violently shake while driving, continue to run but all of the lights on the console come on. If at a stop the car will just die. Acts as if the battery is dead, but waiting a short time will allow me to start the car. OBD code is either no codes or “System Voltage Low”. Anybody have any ideas?
Have an in vehicle load test done to check the charging system.
Original battery? You didn’t say.
I suggest having the battery and the charging system tested. Many auto parts stores will do this free.
