when cold, i can start and drive the honda. but at temp, it will idle, but stall when throttle applied. iv already changed the fuel filter.
how about the air filter? could it be plugged? when was it changed?
Clean the throttle body. If that doesn’t help, likely a bad idle air control valve.
