r.h window intermittent up or down,
Do you have a question? As for your window, likely the switch or the power window motor. Test each, change the one that fails.
yes as its intermittent I suspect sw or bad connection somewhere in system,question is this hardwired or use a controller.
Brent, don’t go looking for zebras when a horse is standing in front of you. Start with the simple things - switch first, motor 2nd.
rodger that
