Doesn’t shift into. 2/3 gear with a sound
When was the last trans fluid service?
For how long have you been using a touch screen keyboard?
1990 Cadillac with transmission problems . No surprise there , end of discussion ![]()
Ask the shop techs who usually work on your car which is the best independent transmission shop in the area, then take your car there. This sort of problem usually requires a professional transmission shop diagnosis. It may be the transmission shop diagnosis points to a problem your normal car-repair shop can fix.
