I’ve gotten some great advice from a couple of people on here about my non working wipers. Thank you for that. Can anyone tell me where the wiper control module is located? There is nothing mentioned about it in my Haynes manual. Thanks in advance.
Remove the drivers lower instrument panel cover, you’ll find the wiper module by your knees.
The wipers should work on high speed without the wiper module. Turn the wipers on high and touch the wiper motor housing with your test light to see if it has a good ground.
Test for power at the motor;
high; red/yellow wire
low; brown
park; dark blue
