The smart junction box is difficult to remove, and the fuses are very difficult to access, so much so that removing the smart junction box may be easier to check fuses. Putting a foam mat down for your back may help as you have to look up and reach up from below the dash. It releases and then slides up I believe. If you pull it out before it is all the up it will break the plastic. Once it is out you can disconnect the wires if needed. There is an access cover on the left side that allows some access to the area from the side.
