What wheels interchange with jeep? 95 Cherokee
Try a scrapyard which should have a Hollander interchange book. I can’t say if it will help with both the lugbolt pattern and the tire diameter. For tire diameter equivalents, Google “Tire Size Calculator”. The Miata one is good.
This is something to go on; can’t say it will do the whole job. Perhaps others can do more for you.
You need to know the wheel stud pattern and size as well as the offset.
Way back, Ford, Chrysler and Jeep used the same 5 lug pattern. But today, who knows? There are now a million different wheel dimensions…
