Wheel Speed sensors
Anyone know where I can find wheel speed sensors for a 1995 Chevy G20 van. I have been looking a long time with no luck!
Are you looking for the one at the rear of the transmission?
If you can’t find it here, then it doesn’t exist.
https://www.gmpartscenter.net/
RockAuto
https://www.rockauto.com/en/moreinfo.php?pk=6310143&cc=1046797&jsn=488
Thanks, but what I am looking for is for the rotors along with a dust shield!
Which is it? Wheel speed sensors, or rotor/dust shield?
So the rotor is not a sensor and what rotors? The toothed wheel? Available at Rockauto as well. Does this van have rear only ABS? Or 4 wheel ABS?
If it has rear wheel ABS, I would remove it as they are junk.
If you can’t find the part you need new from a parts place, ask at your local auto parts recycler too. Pick N Pull and the like. They might not have it on hand, but can order it for you from another parts recycler. They’ll also have a master list of what other vehicles use that same part.
On this vehicle, I believe the front speed sensors are pretty much permanently attached to the backing plate
the tone ring is part of the front rotors
